Random Sampling from huge point data
4515
05-18-2011 06:06 PM
MilanBudhathoki1
Hi everyone,
I have 35,000 points datasets. It is tedious to incorporate all points for my analysis. I am trying to generate random sample points in ArcGIS 9.3.1 platform. Is it possible run sampling technique in ArcGIS 9.3.1?
Any kind of suggestion is welcome.
Thanks!
JeffreyEvans
Here is code in R. It requires the rgdal library. If you search around the forum there are some example scripts for calling R from ArcMap. Here is one example form the ESRI scripts page.
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=F855D6D1-1422-2418-A0B2-643E6...
# PROGRAM: RandomFeatureSample.R
# USE: RANDOM SAMPLING OF SPATIAL OBJECTS
# REQUIRES: SP CLASS SpatialDataFrame OBJECT
# FUNCTIONS:
#   RandSP(x, ns=10, reps=1, replace=FALSE)
# ARGUMENTS:
#   x        SP CLASS SpatialDataFrame OBJECT (POINT, POLYGON, LINE, PIXEL)
#   n        NUMBER OF RANDOM SAMPLES
#   reps     NUMBER OF REPLICATES (STRATA)
#   replace  SAMPLE WITH REPLACEMENT (DEFAULT FALSE)
#   ...      OPTIONAL ARGUMENTS TO PASS TO sample
# VALUE:
#    SUBSAMPLE OF SP FEATURECLASS AS SAME SP CLASS
# NOTES:
#   IF REPLACEMENT IS FALSE FEATURES ARE REMOVED FROM CONSIDERATION IN SUBSEQUENT
#   REPS
#     THIS MEANS THAT IF TRUE, THAT A FEATURE CAN BE SELECTED MULTIPLE TIMES ACROSS
#     REPLICATES. NOT RELEVANT IF REP=1.
# EXAMPLES:
#   require(rgdal)
#   require(sp)
#   # READ SHAPEFILE USING RGDAL
#     shape <- readOGR(dsn="C:/test", layer="polys", driver="ESRI Shapefile")
#   # CREATES 4 REPLCATES WITH 5 RANDOM SAMPLES EACH WITHOUT REPLACEMENT
#     ssample <- RandSP(shape, n=5, reps=4, replace=FALSE)
#   # CREATES 1 REPLCATE WITH 10% RANDOM SAMPLE WITHOUT REPLACEMENT
#     ssample <- RandSP(shape, n=round(dim(shape)[1]*0.10), digits=0), reps=1, replace=FALSE)
#   # WRITE RANDOM SAMPLE SHAPEFILE USING RGDAL
#     writeOGR(ssample, dsn="C:/test", layer="RandSample", driver="ESRI Shapefile")
#   # PLOT RANDOM SAMPLES COLORED BY REPLICATE
#     spplot(ssample, "REP", col.regions=terrain.colors(n=length(unique(ssample@data$REP))))
# REFERENCES:
#    B.D. Ripley, 1981. Spatial Statistics, Wiley
# CONTACT:
#     Jeffrey S. Evans
#     Senior Landscape Ecologist
#     The Nature Conservancy - Central Science
#     Laramie, WY
#     (970)672-6766
#     [email protected]
RandSP <- function(x, n=10, reps=1, replace=FALSE, ...)
    if (!require(sp)) stop("sp PACKAGE MISSING")
 if (!inherits(x@data, "data.frame")) stop("MUST BE SP SpatialDataFrame OBJECT")
    spx <- x
 if ( dim(spx)[1] > n ) {
   s <- sample(1:nrow(spx@data), n)
     results <- spx[s, ]
       results@data <- data.frame(results@data, REP=1)
    if(replace==FALSE) { spx <- spx[-s, ] }
   if(reps > 1) {
 for (i in 2:reps ) {
        ssamp <- spx[s, ]
   ssamp@data <- data.frame(ssamp@data, REP=i)
       results <- rbind(results, ssamp)
  return( results )
MichaelMcManus
The R package spsurvey can draw random samples, as well as spatially balanced probabilistic samples, so you might check out that package.  Here is a web site that describes some survey applications using spsurvey:
http://www.epa.gov/nheerl/arm/
Mike
