Predicting a lake shape 6 years later
1585
01-22-2013 12:52 AM
MOHAMMEDHABBOUB
Hi there,
I'm looking forward predicting a lake shape 6 years later, in the same condition trends, I have 20 shapefiles describing the shape of the lake in a series of years.
and how could I make a the DEM to contribute because it will affect the shape of the lake
Could anybody give me a hint?
WilliamFarebrother
Hi Mohammed,
If you download a SRTM DEM or similar DEM for your lake region you could convert your polygon to a series of points (i.e. feature vertices to points) and then using the extract values to points (using the DEM as the raster source and the vertices points as the point feature) it will give you the elevation of the lake shoreline at each point. This would allow a crude estimation of any trends between each year. To predict future lake shorelines you could use predicted lake shoreline elevations and fill the DEM to that elevation effectively creating the predicted lake shoreline
Dakota_20
MOHAMMEDHABBOUB
Hi Mohammed,
Dakota_20
That's nice but the problem is that the lake is shrinking not expanding and the DEM doesn't tell me the elevation under water so I can't get the elevation under water body !!
MarcoBoeringa
The only reliable way in case of a shrinking lake would be to determine the bottom surface by means of sounding, for example using a multi-beam sonar, and than use that to fill up the gap in the DEM.
A crude alternative is to determine some weighted centre point of the smallest circumference, and than model the shrinkage in let's say each degree direction of 360 degree round based on your existing shapes, and than use that somehow as input for an ArcGIS spatial adjustment rubbersheeting operation to automatically define "displacement links".
But this isn't going to be an "easy" solution and modelling operation...
