Optimized Hot Spot Analysis
3095
6
12-20-2017 08:44 AM
DevinUnderwood2
I keep getting a cell size of 57 feet which is automatically set.
I want to manually set the cell size of the generated fishnet  polygons around the points.
I tried the environment settings XY Resolution Tolerance but the tool ignores my input.
How can I get this to work or is there another way ?
Thank you
DanPatterson_Retired
In Pro there is an option to set the cell size within the tool
http://pro.arcgis.com/en/pro-app/tool-reference/spatial-statistics/optimized-hot-spot-analysis.htm
The computed settings used to produce optimal hot spot analysis results are reported as messages during tool execution. The associated workflows and algorithms are explained in How Optimized Hot Spot Analysis works.
instead of letting the tool choose optimal defaults for grid cell size and scale of analysis, the Override Settings can be used to set the Cell Size or Distance Band for the analysis.
And further information can be found here.
http://pro.arcgis.com/en/pro-app/tool-reference/spatial-statistics/how-optimized-hot-spot-analysis-w...
in picture form
DevinUnderwood2
Great advice, I don't have access to Pro yet.
Would have been real easy to use this setting.
I have looked at the correlated documentation and have not come across a solution.
This Optimized  Hot Spot Analysis is convenient also since it gives me counts per polygon
My alternative requires several steps.
Point density (raster)
Change raster (float to integer)
Raster to polygon
Spatial Join to get counts (Requires cleaning up or ensuring all point density output have 100 foot squares.
check it out in ArcMap... I not sure what the problem is, since the cell size option is present in both incarnations except Map has the pictures and Pro doesn't
DevinUnderwood2
  ArcMap doesn't have override settings.
The second link was arcmap 10.5.1... you must be using an older (as yet unspecified) version, in which case, just use the Hot Spot analysis as indicated in the help topic.
Per
