Manual Local Moran's Index calculation
5817
02-09-2014 12:25 PM
GaryNobles
Dear Forum,
[edit: excel attachment added]
I have been successfully applying the Local Moran's Index (and Gi*) as part of my PhD, but I want to know exactly how the calculation is achieved. I am an archaeologist and I will be writing this in my thesis, so I must present it in a way other non-statisticians can understand it.
I decided to produce a worked example, for Gi* it was simple but I'm having difficulty calculating a single instance of the Local Moran's i (Li).
Thank you in advance for any help you can give me, I really want to crack this as I am just starting my writing up phase (and it's bugging me)!
The ESRI implemented equation is here: http://resources.arcgis.com/en/help/main/10.1/index.html#//005p00000012000000
Here is the local neighbourhood (of a larger dataset 11x11 cells), the target cell is 100.
73|96|82
96|100|92
87|93|82
Neighbourhood average = 87.63
Here is my workings, there is an error which I point out as you go through it.
To get Si^2
sum of al the neighbours minus the mean then squared
this is divided by the number of neighbouring cells minus 1 (the target cell)
this calculation is then subtracted from the mean squared
so:
�??(73-87.63)�??^2+
�??(96-87.63)�??^2+
�??(87-87.63)�??^2+
�??(96-87.63)�??^2+
�??(93-87.63)�??^2+
�??(82-87.63)�??^2+
�??(92-87.63)�??^2+
�??(82-87.63)�??^2     =465.88
then...
Si^2 = 465.88/(8-1)-7678.14= -7611.59
We have to take the value of a neighbour and subtract this from the average of neighbours and multiplied by the search radius (wij)
so:
((73-87.63)*1.75)=-25.60
((96-87.63)*1.75)=14.6475
((87-87.63)*1.75)=-1.1025
((93-87.63)*1.75)=9.3975
((82-87.63)*1.75)=-9.8525
((92-87.63)*1.75)=7.6475
results summed = -0.07
It should equal -11240.16
This would create the calculation:
I-index=  (100-87.63)/(-7611.)* -11240.16=18.27
Which is what ArcGIS produces, where have I gone wrong?
Thanks, Gary
PriyankaDhar
Could you please explain what is the source of the" -11240.16" value and how to calculate?
