K nearest neighbors or other conceptualization for Hot Spot Analyisis
2711
04-21-2011 09:34 AM
HuaqiYuan
Hi there,
I have a dataset which are skewed (not normally distributed).  And I have used SPSS to prove that by applying the normality test. Under this situation, do I use the K nearest neighbors with 8 neighbors as suggested by the documentation for the Hot Spot Analysis or other conceptualization like fixed distance band with neighbor parameter.  I have found out the results from these two conceptualizations are quite different (maybe due to the skewed nature of the data).  So I would like to know which conceptualization I should choose based on your experience.
Thanks!
Franky
LaurenRosenshein
Hi Franky,
You are right that if your data is skewed you want to ensure that your features all have at least several neighbors, and 8 is a good rule of thumb.  The question of whether to use K-nearest neighbors or fixed distance is really determined by the question that you're asking.  Fixed distance is often a good option because it ensures that your scale is consistent across the whole study area, but if you want to ensure that all of your features have at least 8 neighbors what you might want to do is use the "Generate Spatial Weights Matrix tool", which allows you to set a fixed distance (and choose your fixed distance according to the question that you're asking), and then optionally lets you set a minimum number of neighbors.  That way it will use the fixed distance band everywhere, but for those features where the fixed distance does not ensure that a feature has 8 neighbors, it will extend the distance just for those features to ensure they have the minimum number of neighbors that you set.
Hope this helps.
Lauren Rosenshein
Geoprocessing Product Engineer
RyanWilliams1
Hi Lauren,
Do you happen to know the algorithm behind the K nearest neighbor option? For example, is it measuring feature edge to feature edge or centroid to centroid?
Thanks. Ryan
