Graduated colors
4464
10
06-27-2016 11:00 AM
TsvetelinaGeorgiev
Hi
When trying to create a graduate color quantities symbology and clock ok the map despairs only the borders of the map stay. Any suggestions? thank you
DanPatterson_Retired
Ok... you show a single polygon, which has a class which appears to be symbolized as clear.  If you are only mapping one polygon, why are you using a graduated symbol class or are you hiding some of the other polygons?
