given a paper map with a point pattern, which type of statistical tests can be run without converting to a gis map format?. also what is the best way to convert this paper map to one that is gis - based
3748
09-30-2015 12:20 PM
hhet
Tags (1)
RickeyFight
To answer your second question,
I would scan the paper map--> Convert to Tiff--> Georeference the Tiff--> digitize the point pattern.
DanPatterson_Retired
some tests...we used to do old school...albeit added by a calculator
  • mean center and standard distance
  • nearest neighbour analysis
  • join count
  • Moran's (for smallish areas)
  • to name a few
DarrenWiens2
Given enough time, you can do absolutely any statistical tests by hand that a GIS can do for you (kind of defeats the purpose of GIS, though).
Darren...the difference is...by doing it by hand you absolutely have to know what you are doing no defaults... no press OK
