fill empty polygons with neighbors average
3942
06-17-2014 03:05 AM
JuliánBetancur
Good morning,
I would like to fill empty polygons with its neighbors average, What tool should I use?. In the image you could see the problem, that I want to solve for using a grouping tool,
Thank you![ATTACH=CONFIG]34641[/ATTACH]
JuliánBetancur
What version of ArcGIS are you using 9.3, 10.0, 10.2?
I am using ArcGIS 10.1, so I can not use that tool and also I need to fill an empty polygon using the average of the attributes of the surroundings polygons, not the characteristics such as length, etc.
I appreciate your answer and Thank you very much for the help.
