Create Composite Line
2245
09-27-2010 04:15 PM
KeithSandell
Does anyone know of an out-of-the-box tool or ArcScript that takes completely dissimilar lines (at least two or more) and creates a composite line that's length and geometry is based on a statistical (average, mean, etc.) measurement of the input line values?
Similar to a best-fit line for a group of points, but this output would be a best fit for lines and not necessarily be a straight-line, i.e. if the inputs had many vertices then the output would have a similar number of vertices.
I've attached a crude picture of what I am trying to accomplish. The Red lines are the inputs and the Black line is the hypothetical output.
This seems like it could be a very complicated undertaking and I don't want to reinvent the wheel if someone has already thought through this, or any thoughts about how I could best go about accomplishing this, thanks?
KeithSandell
...there is an effective and theoretically justified solution...
Bill,
Wow! Your solution sounds like it is the cat's meow and certaintly sounds sound, but a little above my "current" level. No different from my past 4 years in GIS...there is always something new to learn. Thanks for the great info.
I'll look into this!
ammarafaneh
hi,
Im sorry i cant help you but you might be able to help me !
you mentioned that you dont want a best fit straight line for a group of points... I DO !
do you know how can i do that ???
i have a shape file with a lot of points in it and i wanna graph a best fit line for a selected group of them... i'll really appreciate it if you can help me
Regards,
Ammar
ammarafaneh
thanx whuber
i know how to do it mathematically i actually use linear regression
i wanted to do it in ArcGIS .. code or tool or something like that
