Clustering points based on geographic location (an island)
1027
11-15-2012 06:04 AM
AndreaDort
Dataset of 6500 points distributed over a geographic area (an island).
I need to find where these points significantly cluster and also view outliers. Cluster/outlier analysis doesn't seem to help since it requires an input field and because I want to evaluate based on location, the point file has no relevant fields.
Essentially I need to identify clusters of points within a specific search area (the island).
Any ideas??
Big thanks
Andrea
ObiOfoegbu
Any ideas??
Big thanks
Andrea
Have you tried the buffer tool to atleast visually give you the clustered points and show outliers. You can either use linear or field to specify what points would be close to each other and visually have a polygon feature around the clustered points. Outliers would be polygons with fewest points in them. Hope this helps
KristinAldous
Hi Andrea,
It sounds like you might be able to use hot spot analysis with some data prep.  The help topic gives and explanation of using the 'fishnet tool' or a spatial join to get a count of points within a grid or local area.
http://resources.arcgis.com/en/help/main/10.1/index.html#//005p00000011000000
