Cluster Analysis for multiple criteria
1624
09-08-2013 04:15 AM
JaroslavOlegovich
Hello!
Is it possible to perform Cluster Analysis (Need Hot Spot Analysis) for multiple critearia?
I have a .shp file with polygons, each polygon has several fields: A,B,C,D,E.
Is it possible to find clusters based of ALL fields A-E?
How can I do it?
If its not what is the best way to carry out this cluster analysis? I can perform Hot spot analysis for each field - have several layers - combine them?
Thank you very much!
XanderBakker
Esri Esteemed Contributor
Hello!
How can I do it?
Hi Jaroslav,
I think the new "Grouping Analysis" (10.2) could be just what you are looking for:
Help on Grouping Analysis (Spatial Statistics) 10.2 and How Grouping Analysis works
Kind regards,
Xander
