Selecting specific polygons from criteria
2387
01-21-2017 01:38 PM
MalcolmLittle
I have two distinct polygon datasets (both projected the same: NAD 1983 Albers) of lakes and islands in British Columbia. I need a tool/module that’ll select all the lakes that contain an island. Then I need to select from that result the lakes that have surface areas larger than 20 hectares. Working with ModelBuilder, so referring to a model diagram would be appreciated but not necessary.
AbdullahAnter
Honored Contributor
Just you need to use 2 tool :
1- Select Layer By Location to find  the lakes that contain an island. Select Layer By Location—Help | ArcGIS Desktop
2-then Use Select Layer By Attribute to select areas larger than 20 hectares. don't forget to make selection method/type in this step " Select from Currant Selection / Subset selection". Select Layer By Attribute—Help | ArcGIS Desktop
AbdullahAnter
Honored Contributor
DanPatterson_Retired
One problem you may run into is if the islands are a bit of a multipart polygon... that is, they are not separate records in the table, but geometrically may be ajoined to the nearby landmap.  You might be advised to select by attributes features whose area is less than some probable island-sized value (make sure you are using projected data).  Once those values are selected,  use the lakes to select from those features that are completely within the lakes.  Of course... this assumes that the lakes form a separate layer... if not then things get a bit more complicated.
JoshuaBixby
MVP Esteemed Contributor
With the lakes dataset, are islands represented by holes in the lake polygon, or are lakes whole and then you have to overlay islands on top of water?  I ask because how exactly the data is structured drives the methodology, as others have indicated with their comments.
