Points to Service Area / Boundary
4728
6
03-20-2015 10:46 AM
codybuntz
Hello All,
Does anyone know of a way I can take a large set of points (1 million plus) and create some sort of boundary or service area out of them?
I know this can be done manually but I would like to find an automated solution.
JakeSkinner
Esri Esteemed Contributor
Hi Cody,
Take a look at the Minimum Bounding Geometry tool.
codybuntz
Hi Jake, Thanks for the reply.
The Minimum Bounding Geo Tool works, but only gets me about 50% there.
I was looking for something that creates a little bit tighter of a polygon (not as square).
The more i research, the more i am starting to believe that only way i can get the result i want is to hand draw the service area.
JakeSkinner
Is the 'Convex Hull' option not what you are looking for?
IanMurray
Honored Contributor
Are your points numbered or sorted in any meaningful way in your attribute table?
codybuntz
The only meaningful sort could be an Account # or Grid #. They have a UID and other unique identifiers but nothing sequenced.
GrahamW
any which way you do this it's going to be "a cat out of a bag" sort of solution
None of these suggestions are perfect but it could be in the form of:
  1. To create dissolved buffers then debuffer back once the disolved edges are joined
  2. To use a central point (or 5,10 or++ if necessary) and point to line to this point(s) and buffer results and fill the gaps..
  3. Manually edit the convex hull result
  4. Assign an ID that is sequential based on location coordinates..(eg in a specific diagonal direction north 1st then east sorted)then point to line based on the sequential ID again you may need to split the points into groups for a good result. I've used MS access for this before.
  5. find more data to relate it to... eg properties
