Point Distance based on Attributes
4015
05-26-2015 10:46 AM
GaryBarden
What's the easiest way to calculate the distance between 2 points, from 2 different features, that have matching attribute?
Gary Barden
JakeSkinner
Esri Esteemed Contributor
Hi Gary,
You could accomplish this with a python script that uses the Point Distance tool.  Below is an example that creates an individual feature layer based on an attribute selection for each feature class, and then runs the point distance analysis on these two points.
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
env.overwriteOutput = 1
fc1 = "pointA"
fc2 = "pointB"
#retrieve unique field values
valueList = []
with arcpy.da.SearchCursor(fc1, ["PIN"]) as cursor:
  for row in cursor:
    list.append(row[0])
del cursor
#run Point Distance analysis
firstTime = 1
for value in valueList:
  if firstTime == 1:
    arcpy.MakeFeatureLayer_management(fc1, "fcLyrA", "PIN = '" + value + "'")
    arcpy.MakeFeatureLayer_management(fc2, "fcLyrB", "PIN = '" + value + "'")
    arcpy.PointDistance_analysis("fcLyrA", "fcLyrB", r"IN_MEMORY\pointDistance")
    firstTime = 2
  else:
    arcpy.PointDistance_analysis("fcLyrA", "fcLyrB", r"IN_MEMORY\pointDistance_" + str(value))
    arcpy.Append_management(r"IN_MEMORY\pointDistance_" + str(value), r"IN_MEMORY\pointDistance")
#export table results
arcpy.CopyRows_management(r"IN_MEMORY\pointDistance", "pointDistanceResults")
JakeSkinner
Hi Gary,
import arcpy
fc1 = "pointA"
fc2 = "pointB"
valueList = []
  for row in cursor:
    list.append(row[0])
del cursor
firstTime = 1
  if firstTime == 1:
    firstTime = 2
  else:
