Just started using ArcMap - is this kind of analysis possible?
13649
43
06-24-2015 10:03 AM
ElioD_Aversa
I have 2 files, a shapefile (.shp) and a raster file (.tif). The .tif is merely 2 bands (0 and 1) where 0 represents no forest loss and 1 represents forest loss (file is from here: http://earthenginepartners.appspot.com/science-2013-global-forest/download_v1.1.html) The .shp consists of polygons that represent protected areas (file is from here: http://www.protectedplanet.net/).
What I'd like to do is try a statistical analysis that would simply tell me how much forest loss ("1" points in the .tif) lies within the protected areas and how much loss lies outside the protected areas (in the .shp).
I'm wondering if it's possible to do this in arcmap/arcgis and if so how would I do this?
Sorry if this seems like a stupid question, I haven't been using the software for long and I couldn't find anything online.
SepheFox
What kind of computer are you running ArcMap on?
ElioD_Aversa
It's a desktop with 64bit windows 7, a reasonably fast AMD quadcore, GPU, 8GB RAM and a SSD hard drive. Even so it has taken my PC all night to work through all these suggestions with trial and error, I don't mind as I'm doing this for a university project but for someone with less time than me I think you'll want to cut down the file sizes
SepheFox
Yes, the first thing I did was resample the raster. I think for this level of analysis you can get away with a larger cell size. This enabled me to perform a Tabulate quite quickly. Unfortunately, since your data is in Geographic Coordinate System (lat/long) the area result is in degrees, which is meaningless. So step two will have to be Projecting the raster into a local coordinate system, such as UTM.
ElioD_Aversa
Ok for the resample (as that sounds like a fine idea) what's best to put in the fields (Cell size, X, Y, Technique)? I think you're right the larger cell size won't hurt the result too much and if it means I can cover a larger area in the time I have then it's worth it. Also would you mind sharing what you input for tabulate as well? I think I can change the coordinate system (or easily look it up) so at least I have that one covered.
It's much easier when someone knowledgeable helps with this so I appreciate it, I'm learning
SepheFox
Here's the resample:
Then I projected it into a generic South American projection:
Finally the tabulate area:
Giving me this result:
This is the area of those values, within the overlapping polygon, in square meters, because that is the unit of the coordinate system I picked. You should probably finesse all this if you want to do it right, but this should get you going.
ElioD_Aversa
Thank you very much I cannot begin to explain how helpful this has been. You've made it look easy I will go through it later as soon as I'm back at my PC. Would it be possible to PM you later? Is that possible here? Otherwise I'll update this thread again with my results.
Cheers!
SepheFox
You can only PM if you follow each other. I don't mind, but it's really nice to finish the thread here, so that others can benefit from the info.
SepheFox
244,669 square miles of value 0
3,428 square miles of value 1
SepheFox
It's pretty cool just examining the data visually, you can see how the protected areas have much less forest loss:
ElioD_Aversa
I know! I noticed that immediately, it's so cool I've decided to do a whole project on it
