Human Movement
3862
6
02-04-2016 06:27 AM
BaffourAwuah
Can someone help me out? I'm trying to use Distributive Flow Lines Tool for Human Movement  Analysis, but unfortunately I keep on getting this Error Message: Traceback(most recent call last); File “<string>”, line 136, in updateParameters ValueError: invalid literal for float(): 1009529,06119841. Can someone help me out?  Does ArcGis provide any other tool for that purpose?
DarrenWiens2
The problem is to do with using a comma separator.
>>> myString = '10000,02837'
>>> float(myString) # it doesn't work
Runtime error
  File "<string>", line 1, in <module>
ValueError: invalid literal for float(): 10000,02837
>>> myString = '10000.02837'
>>> float(myString)
10000.02837 # it works!
Try changing all the commas in that field to periods.
DanPatterson_Retired
Since that is not a part of the esri suite of extensions...perhaps you could elaborate as to where this might be obtained... but based on 1009529,06119841  ​could you post the code if you have it...if it is in python
DarrenWiens2
Runtime error
>>> float(myString)
Darren may be on to something... try to see your regional settings and look for the 'decimal_point' separator option.  In this example, you will see that a period is used in Canada
>>> import locale
>>> loc = locale.getlocale()
>>> loc
(None, None)
>>> locale.localeconv()
{'mon_thousands_sep': '', 'mon_grouping': [], 'decimal_point': '.', 'p_sep_by_space': 127, 'int_curr_symbol': '', 'n_cs_precedes': 127, 'positive_sign': '', 'p_sign_posn': 127, 'n_sep_by_space': 127, 'p_cs_precedes': 127, 'thousands_sep': '', 'negative_sign': '', 'frac_digits': 127, 'n_sign_posn': 127, 'currency_symbol': '', 'mon_decimal_point': '', 'int_frac_digits': 127, 'grouping': []}
BaffourAwuah
Dan and Darren, thanks for your suggestions. I need to talk to our administrator before changing the local settings, right?  I downloaded this program from: Distributive Flow Maps – More Raster, More Faster | Applications Prototype Lab.
BaffourAwuah
That is absolutely Perfect. It worked like Magic. Thanks, once again, Dan and Darren!
XanderBakker
Esri Esteemed Contributor
Hi Baffour Awuah I unmarked your own post as the correct answer. Could you mark the thread that answered your question as the correct one?
