Hi Guys,
I'm hoping someone can help me here.
Is there any way that I can flip line features so that the starting point of the line is starting at another feature (point feature)
I hope I'm making sense as I know my wording probably isn't correct.
ps. I'm using ArcGIS Editor 10.1
Thanks in advance for your help/advice.
One approach could be this:
As you "only" have ArcEditor you cannot use Feature Vertices To Points (Data Management) tool to create the FROM nodes, you'll have to do a little bit more research, I suggest the code gallery or ArcScripts.
Hi Dan,
Thanks for your reply.
The thing is this only allows me to do 1 line at a time & secondly, some line features already start at a feature and some don't.
As I have a lot of line features I was hoping there was a quicker way of doing this and checking to make sure all lines start at a feature?
Sukh
Hi Duncan,
Thanks for the links provided.
The real issue I have is that at not all lines are flipped the right way? some lines already start at a point feature but some don't.
Is there anything I can do to select the lines first that don't have their starting point at a feature and flip only those?
I don't do much editing, but I would be surprised if you couldn't select several lines by holding the shift key and clicking then flipping...but as said..the last time I edited geometry was many years ago
Hi dan,
You're right . I can turn on arrow heads and then select multiple lines buy visually selecting.
the only problem is that I have 1000s of lines and this is where I'm hoping to find a quicker solution.
There isn't one...unless you have funds to hire an undergraduate assistant
Ah well, that answers that then.
Thanks for your help guys.
