Hello,I have a question about file size. I'm with these specifications:
File 1: polygons / file size
1) x_polygons.cpg = 1KB
2) x_polygons.dbf = 4 KB
3) x_polygons.prj = 1KB
4) x_polygons.shp = 36.263 KB
5) x_polygons.shp.xml = 6KB
6) x_polygons.shx = 1KB
File 2: points / file size
1) x_points.cpg = 1KB
2) x_points.dbf = 599.740 KB
3) x_points.prj = 1KB
4) x_points.sbn = 8,813 KB
5) x_points.sbx = 94 KB
6) x_points.shp = 29,722KB
7) x_points.shx = 8,492KB
When you cross the information from both (Analysis Tools -> Spatial Join) always returns a very large file shape (size = 2,097,217 KB). This is the size limit of a shape file, right? This happens regardless of the size of the files examined by Spatian Join.
Why does this happen?
Another thing seems missing files for polygons layer. It does not have files in the following extensions: .sbn and .sbx. This layer was generated from the merge function.
PS: the two files are in the same geodatabase, inside a folder with a short name and near the root. The files are also in the same projection.
Thank you!
