Error on the Esri Maps for Business Objects
4139
07-08-2014 07:31 AM
LuizFilho
After the installation is done successfully, we are encountering the following errors:
we are encountering the following errors: I did all the procedures reported in the article (42351 - Location types are missing when adding data from a business system), still not working.
Another error found, was in the method of authentication "user" or "app" setting. When I set up to use the method "user " dashboards in BIPAD work, but on the other hand, the Esri Maps Designer tool, found in the Client does not work.
When I select the authentication method "app" the opposite happens, the Dash stop working in BIPAD and Esri Maps Designer works.
See the attached figures.
LuizFilho
?? News ??
