Auto Populate by spatial reference fields line/polygon
3941
09-21-2015 05:56 AM
TyeDesiderio
Hey guys,
I have a line feature class(streams) that contain a field called "Watershed" in it. I also have the HUC 12 Watershed boundaries feature class  in ArcMap. How do I auto populate the streams feature class field called "Watershed" by spatial referencing  to the watershed they fall into with the HUC 12 feature class. Any suggestions? Thanks.....
TyeDesiderio
The HUC 12s are a polygon feature.
TimothyHales
Esri Notable Contributor
You should be able to use the Spatial Join tool to accomplish this. Also see these resources for more information:
About joining and relating tables—Help | ArcGIS for Desktop
Spatial joins by feature type—Help | ArcGIS for Desktop
TyeDesiderio
Ok...sounds great. However, I didn't want to create a new layer or feature. Just auto populate the field. The layer of streams is on my companies server and it is the base layer for everyone. I just didn't want to type in the watershed name for all the streams. Hope this helps. Thank you. Much appreciated.
LeonardoCarvallo2
Want to know which streams belong to a particular basin ..? Try the tool intersect. This should extract the attributes contained in each polygon.
