Settings on a mission selection tools such as ( Layers > Elevation Data), need to be based on the users last input.
Problem: Right now if one user changes the setting like contour interval….it changes it for everyone on the fly and then if two users are in the same mission it will cause export output problems if one user make a selection and then the second user changes that selection and then the contours are exported.
The last user selection should be saved under that users profile so each time the user visits that Layer tab their last selections should still be there.
