Site Scan LE app - support MDM app config eg portalurl
650
02-10-2022 12:09 AM
ZoltanKelly
New Contributor III
We have configured Site Scan LE with our MDM (Mobile Devce Mgmt) platform (Citrix) to use with ArcGIS Enterprise behind a firewall using a per-app VPN on iOS and it’s working as expected and can connect.
It would be great if the app supported MDM appconfig parameters like the other Esri mobile apps, at a minimum/specifically portalURL so this was configured by default when deploying without users having to enter it manually.
The Field Maps useinappauth mechanism would also be preferred as it limits the need for allowing global device safari domains, by using a web clip for the authentication popup. This is also a cleaner user experience - hopefully this becomes standard across all Esri mobile apps .
2 Comments
NicoBonnafoux
AndrewBowne
Additionally - if not using MDM, to be able to store Portal URL and login info similar to other Esri mobile apps.  that way you don't have to enter a portal url , username, password, every time you log in to Flight...
