Choosing Ground Elevation Layers in AGOL TOC Scene Viewer vs Apps
126
a week ago
Status: Open
Labels (3)
vmnblack_wsp
Is there any way to keep the ability to select which ground elevation you want to display for the Scene Viewer? In the actual Scene Viewer itself, in the TOC there is the ability - but as soon as you put the exact same scene viewer into either an app or you link to an ExB, the options for Ground Elevation disappears?
Scene Viewer TOC (option for Ground Elevation to toggle options on and off in both TOC and Layers on Mapframe - correct):
But if you insert as a Map Widget in an ExB or even have the with a Layer widget connected to that same Scene Viewer, then you lose the ability to toggle on and off the ground elevation layers:
Attempted an instant app from the original Scene Viewer as well and that also does not have Ground Elevation:
The only way I can get it to work, is to embed the link of the scene viewer into an ExB, but then you get unnecessary headers and footers, and when you set the URL to have ui=min to remove the headers, it then also removes the layers and Scene Viewer URLs do not seem to support a showLayers parameter. and this also is not ideal as you then don't have the ability to link 2D maps with the 3D maps via the Extent Changes / Map actions.
We need to be able to toggle the elevation layers as these are separate scenarios and can not relay on the order of elevation layers in the TOC.
Does anyone know of a workaround to get the Ground Elevation options to show up on the TOC?
