Event Editor Error
1483
09-26-2019 11:16 AM
anayoung
Hello,
Does anyone know why this error occurs in Event Editor?
Network issues?
We are working in 10.7.1 Roads and Highways Event Editor
Ana
KyleGonterwitz
It looks like the error message is telling you that your network the events are registered to is not present in the map service your event editor is using.  Is the network included in the service?
NathanEasley
Hi Ana,
I'd echo what Kyle mentioned before.  Can you make sure all the networks from your LRS are published in the service being used by Event Editor?  If they are all present and you still experience this error, I would suggest opening a case with Esri Technical Support to investigate further.
Nathan
Esri Roads and Highways team
