Error with M value tolerances
1942
04-18-2019 11:19 AM
CameronCole
Hi all,
I am new to Roads ans Highways and are working on initial set up.
I have created an ALRS and are now trying to load a network from a feature class that I already have.
I am receiving an error that states "The selected network units of measure does not match the M Tolerance of the existing feature class."
I am working in the 10.5.1 platform and have let the ALRS create the appropriate tables and feature schema.
I have a route feature class that is M and Z aware that I am trying to use to create the network.
Any help or insight is appreciated.
NathanEasley
Hi Cameron,
I would encourage you to take a look at this topic that deals with tolerance and resolution settings in the LRS. http://desktop.arcgis.com/en/arcmap/latest/extensions/roads-and-highways/tolerance-and-resolution-se...
The error message you're getting points to the XY tolerance/resolution values not matching the expected M tolerance/resolution values.  Take a look at the XY tolerance/resolution, including the units, of the feature class you are trying to register as a network and verify the M tolerance/resolution is the correct conversion.
For example, if the XY tolerance was 0.1 feet and the resolution was 0.01 feet and you wanted to create a network in miles, your M tolerance would need to be 0.00001893939 (0.1 feet/5280) and the M resolution would be 0.000001893939.
Nathan @ Esri
NathanEasley
Hi Cameron,
Nathan @ Esri
CameronCole
Hey Nathan,
Thank you for the documentation.
I was able to use feature class to feature class and then adjust the environments to match those of the R&H document you sent me to! Then the Network was loaded right in after field mapping.
