GP service URL DGN/DWG error on startup
2182
06-06-2024 09:55 AM
Schalkvan_Lill1
Dear all (@NathanEasley),
We've just finished deploying Event Editor on an ArcGIS Enterprise 11.1 instance. When we start the Event Editor application, we are presented with the following error: "GP service URL for adding DGN/DWG in the application configuration has been incorrectly set".
Our understanding is that this GP Service is deprecated at ArcGIS Enterprise 11.1 and it should not be set. Is this understanding correct? Or should we go ahead and publish the GP service from ArcGIS Pro and set the correct service URL in the config file.
Looking forward to hear from you.
Schalk
2 Solutions
NathanEasley
Hi Schalk,
I'd recommend opening up a support case with Esri Technical Support on this.  They should be able to help you troubleshoot why the error is appearing.
Nathan
ArcGIS Roads and Highways team
Schalkvan_Lill1
NathanEasley
Hi Schalk,
Nathan
Schalkvan_Lill1
Thanks @NathanEasley
