Iowa using Esri’s Survey123 software for improved pavement management
1335
01-16-2018 03:24 PM
SeanDolan1
"The quick and easy data access that Survey123 provides helps Iowa DOT determine the most cost-effective way to repair the pavement and make roads safer in the process."
Iowa DOT's Office of Construction and Materials is doing some great work with Esri's "Survey123 for ArcGIS" software.  Read more HERE.
5 Comments
deleted-user-UxcAu2PHrDQp
Motivated and visionary people in the construction office at Iowa DOT.  Having an ESRI technology framework, minimal bureaucratic process, good people  along with an enterprise training plan allows staff to create and be GISuccessful at Iowa DOT.  Thanks for posting.
by Anonymous User
Not applicable
Eric, this is a great example of how Survey123 can be used at a DOT. Is there any chance you could post the Survey 123 form to the Departments of Transportation group? My guess is that other DOTs have a similar form so starting from your form would save time.
by Anonymous User
Not applicable
Thanks Eric! This is great. I’ll try it out.
SeanDolan1
My pleasure, Eric.  Happy to work with you all on this!
