Spatial reference error with arc.write
2148
01-10-2019 04:33 PM
CassKalinski
I am getting the following error from arc.write:
Error in .call_proxy("raster.create", .self, source, as.pairlist(args)) :
No spatial reference exists.
Full call in R:
arc.write(file.path(pathGDB, rasterNameDefault),
rasterDefault,
overwrite = TRUE)
"rasterNameDefault" is a character string. "pathGDB" is the full path to the local GDB. (It is a long path.) "rasterDefault" is a raster layer created with the raster package (via dismo::predict).
I verified the raster has a projection assigned.
> rasterDefault
class : RasterLayer
dimensions : 240, 130, 31200 (nrow, ncol, ncell)
resolution : 845.2344, 845.2344 (x, y)
extent : 353440.7, 463321.2, 4010519, 4213375 (xmin, xmax, ymin, ymax)
coord. ref. : +proj=utm +zone=11 +datum=NAD83 +units=m +no_defs +ellps=GRS80 +towgs84=0,0,0
data source : in memory
names : layer
values : 9.893558e-11, 0.004525617 (min, max)
To be sure, I went back and added this code prior to the arc.write call and reran it. Still get the error on arc.write.
crsProjection <- CRS("+proj=utm +zone=11 +datum=NAD83 +units=m +no_defs")
crs(rasterDefault) <- crsProjection
What is doubly strange is that this is the same exact code pattern that I used in another part of the project about a month ago. It worked fine then and I was able to get rasters into ArcGIS Pro with no issues. Fast forward to today and the function does not work with a different set of rasters. I do not recall any updates to R or Pro during that time.
Versions:
ArcGIS Pro 2.2.4
R-Bridge 1.0.1.232
Microsoft R 3.51
dismo 1.1-4
raster 1.8-4
sp 1.3-1
This code does work and I can add the resulting rasters to ArcPro, but is not as clean as the arc.write in my workflow.
writeRaster(rasterDefault, file.path(pathMaxEntOutputs, "rasterDefault.bil"),
format="EHdr",
overwrite=TRUE,
progress="text",
prj=TRUE)
Thoughts on where I am off here on arc.write?
by Anonymous User
Not applicable
Hello Cass,
Can you please try using arc.write with explicit references to raster properties?
If you have a raster you read in that has the same SR and extents and so forth. I will call that raster object template in the code snippet below
##################################### CODE SNIPPET #########################################
## Create a Blank Raster Conforming to a Pre-existing Raster
output_raster <- arc.raster(NULL, path = 'C:/output_path/Default.gdb/raster_name',
nrow = template$nrow,
ncol = template$ncol,
pixel_type = template$pixel_type,
nband = 1,  ##or how many bands you would like to write
sr = template$sr$WKID,
extent = template$extent)
## Add the Data to the Empty Raster
output_raster$write_pixel_block(raster_data, nrow = template$nrow, ncol = template$ncol)
## Remove the R object for mid-step raster
rm(output_raster)
#################################### END CODE SNIPPET ######################################
Please let me know if that works or not. Also if you have a repro for me to work on, I would be happy to look at what is going wrong when writing the raster in your analysis as well.
Hope this helps,
Orhun
CassKalinski
Thank you for the reply Orhun. It may be late next week before I can test this. (Need to get a draft of my thesis to Dr Kemp!  ) Used the work around I noted for now but do want to sort out the bridge problem.
