problem running R geoprocessing tool
1865
07-24-2018 09:36 AM
GiacomoFavaron
I have an R script which I successfully tested on Desktop and published as a geoprocessing tool.
The tool finds and filters some sql tables and outputs a table in a geodatabase.
But when I run the service I get the following error message:
 Failed to initialize R interpreter. Please install recent version R for Windows Failed to execute (SearchString). Failed to execute (SearchString).
Do I need to have R installed in the same environment of ArcGIS Server?
ShaunWalbridge
Giacomo,
Yes, you do need to have R installed on Server for this to work. When the bridge operates, it operates within a single machine, so for a GP service to call R, it must also have R installed. We've added some documentation on this here:
  Deploying R for ArcGIS Server—Documentation | ArcGIS Enterprise
Cheers,
Shaun
ShaunWalbridge
Giacomo,
Cheers,
Shaun
