Install in multiple labs
1659
04-02-2019 05:55 AM
JoshObrecht1
I manage multiple labs and would like to install this on them. Is there a way to install them without running the script in Toolbox or does that need to be done on every individual machine?
Tags (1)
by Anonymous User
Not applicable
Hello Joshua,
You can now install the R-ArcGIS bridge via the Geoprocessing option in ArcGIS Pro. Out of the box we don't offer automating installing the bridge with the installation of ArcGIS Pro. Is R a part of your image for these machines? If so, we may be able to give you some code patterns for a batch file that sets up the bridge.
JoshObrecht1
R will be part of the image.
by Anonymous User
Not applicable
There are 3 different options:
1-) You can use the following command to install the bridge after you install R from arcgisbinding.zip that is local
./R.exe --vanilla -e "install.packages(pkgs='C:/Users/user/Downloads/arcgisbinding_1.0.1.232.zip',destdir=NULL)"
2-) Similarly, you canuse the github repo location "https://github.com/R-ArcGIS/$repo/archive/master.zip"
3-) You can unzip arcgisbinding and copy it to lib folder in R directory. Note that, if R_Home is not set correctly after installing R this option may not work.
ShaunWalbridge
Hello Joshua,
Was Orhun's answer enough to get you going with this? If you need to configure the R connection for each Pro instance, when you select the desired installation of R from the Geoprocessing options pane, internally all that is happening is creating a new text file, located at %LOCALAPPDATA%\Esri\RIntegration.conf. This file is a text file containing a single line:
R_HOME=<Path to selected R installation>
For example, with R 3.6.0 installed, it might be set to:
R_HOME=c:\Program Files\R\R-3.6.0
Cheers,
Shaun
