WMS Layer Custom Parameter
1214
09-24-2024 02:09 AM
Tsub4sa80
Hi to all, in my application I've a wms chart layer connected to local wms chart server.
For my purpose, I need to send a WMS request with custom parameter "VIEWPORT" instead of "BBOX" parameter (both parameters are not allowed by WMS ChartServer).
Can I remove the BBOX parameter, added by default from ARCGIS library, from the WMS request?
Thank you in advance.
MatveiStefarov
Hello!  Maps SDK lets you add certain parameters to add _all_ GetMap requests (such as an API key or a style configuration), but there is nothing built-in to customize each individual request.
I was able to WMS ChartServer's demo instance in the Maps SDK without problems, and it seems to handle GetMap requests the ordinary BBOX parameter well:
If using the BBOX parameter really doesn't work for your case, then the built-in WMSLayer probably would not work for you.  If you have the ENC exchange sets available, you might be able to use this data directly via EncLayer instead of going through a service.
Tsub4sa80
I solved forcing BBOX parameter to empty string using custom parameters.
Thank you.
