1955
07-05-2017 09:20 AM
_____
LucasDanzinger
Esri Frequent Contributor
you would need to create a function that loops through the baseLayers and referenceLayers of your basemap, and set visibility of all of those baseLayers and referenceLayers to false.
LucasDanzinger
A Basemap object is basically a collection of baseLayers and referenceLayers, so if you wanted to turn off the "Basemap", you would need to iterate through the collections and set the visibility to false - Basemap QML Type | ArcGIS for Developers
_____
LucasDanzinger
MarcWouters
With your hint, I managed hide the basemap by simply clearing the baselayers and referencelayers :
_map->basemap()->baseLayers()->clear();
_map->basemap()->referenceLayers()->clear();
But there is still a gray raster visible, is there a way to get rid of this as well ?
Also when I select a SoilSurveyMap (Specialty/Soil_Survey_Map (MapServer) ), the raster is seen where otherwise water is shown. This is a bit annoying
