Select Features from a WFS service
1592
06-05-2020 07:53 AM
ViníciusCosta
Hello,
I've been wanting to see if I can use use the QML sdk to select features in a WFS service but I have not seem any samples regarding this.
It would be something like the feature layer selection sample but with a WfsFeatureTable instead of a ServiceFeatureTable.
Is it possible?
I did try to just put a WFS
Thanks
LucasDanzinger
Esri Frequent Contributor
The workflow should be exactly the same as showcased in the Feature Layer selection sample - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/Features/FeatureLayer_Selection at master · ...
The data source should not make a difference (whether ArcGIS feature service, wfs, shapefile, geodatabase, etc). The FeatureLayer is the same regardless of the datasource and will handle the various view related operations.
ViníciusCosta
Does anyone have any kind of info on this?
LucasDanzinger
