retryLoad is no work
1852
01-19-2021 10:24 PM
Tkm_Knj
I try to do retryLoad(), but It's no work.
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.9
ApplicationWindow {
    width: 800
    height: 600
    title: "TestMap"
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        // add a map to the mapview
        Map {
            // add the BasemapTopographic basemap to the map
            BasemapTopographic {}
    Shortcut{
        sequence: "F5"
        onActivated: {
           mapType.retryLoad()
 It shoulde be work retryLoad, if  "F5" key is clicked.
But mapType.loadStatus remain Enums.LoadStatusFailedToLoad.
My environment
:Qt 1.15.0 MSVC2019
:ArcGIS 100.9
It something missing or My environment is worse?
LucasDanzinger
Esri Frequent Contributor
Can you connect to the loadStatusChanged and get the error.message and error.additionalMessage when it fails? What does it say?
onLoadStatusChanged: {
    if (loadStatus === Enums.LoadStatusFailedToLoad) {
        console.log("Error:", error.message, error.additionalMessage);
Tkm_Knj
It say  [ qml: Error: Invalid response The service is not tiled].
I get this error when application startup (offline) or click "F5".
By the way, I changed the code as follows, and the [loadStatus] remains [Loading].
    MapView {
        focus: true
        Map {
//            BasemapTopographic {
//                id: bMap
            Basemap{
                ArcGISTiledLayer{
                    url: "https://www.arcgis.com/home/item.html?id=30e5fe3149c34df1ba922e6f5bbf808f"
    Shortcut{
        sequence: "F5"
        onActivated: {
            mapType.cancelLoad()
            mapType.retryLoad()
This code isn't  triggered [onLoadStatusChanged]. (except cancelLoad is called) .
And the map doesn't finish loading and doesn't show up.
I don't need to stick with [retryLoad()] because I want to be able to start it offline and reload it when it comes online after startup...
Do you have any ideas?
LucasDanzinger
I took this code an ran it successfully on my machine - the map loads and displays. Do you have network connection? What platform are you testing on?
Tkm_Knj
yes, I made sure the network was connected when I did the [retryLoad()].
My platform is QtCreator 4.14.0-rc1(4.13.84).
