reading/loading app6b.stylx
1556
02-15-2018 03:45 AM
NorbertThoden
Hi!
I try to switch to APP6-B. I downloaded the stylx file here:
Military Symbology Styles | ArcGIS for Defense
I created the Esri::ArcGISRuntime::DictionarySymbolStyle with following parameters:
  1. const QString& specificationType -> "app6b"
  2. const QString& styleLocation -> "/usr/share/arcgis/resources/symbols/app6b/app6b.stylx"
The file exits and has the correct rights.
Unfortunately i get the signal  'errorOccurred' with:
code=14 domain=0
extendedErrorType=-1,
message='File not found'
There is no documentation, how to setup the parameter specificationType. So i assume "app6b".
Con someone confirm?
Or was someone able to read/load the app6b.stylx???
This problem occures on OpenSuse Linux and Windows based on V100.2.
Thx in advance
EDIT:
Logged to support: "Case #02068526 - reading/loading app6b.stylx fails"
EDIT:
EricBader
Honored Contributor
Hi Norbert. We currently have a bug here, and we're working on fixing this as soon as possible. Stay tuned.
NorbertThoden
Hi Eric!
Thank you!
