Qt C++ Widgets Samples
7023
13
07-27-2022 01:13 AM
RitvikRanadive
Are there any Qt C++ Widgets samples for -
1. Generating offline map for preplanned area and storing it locally
2. Generating offline map on-demand and storing it locally
3. Loading a stored offline map
4. Get GPS coordinates from user inputs like mouse click
Tags (3)
LucasDanzinger
Esri Frequent Contributor
The sample itself deletes the mmpk on exit by use QTemporaryDir. If you modify it to output to a different non-temp location, it won't be deleted.
RitvikRanadive
Are you sure? As I have already tried providing a different path in the following line of code in GenerateOfflineMap.cpp of the example:
GenerateOfflineMapJob* generateJob = m_offlineMapTask->generateOfflineMap(params, "/home/mypath/" + "/offlinemap");
It generated the files at the specified path but there was no .mmpk file in this.
There was mobile_map.mmap file in this but this does not work with the OpenMobileMapPackage example.
LucasDanzinger
The directory with the mmap and various other files is an "unpacked" mobile map package. The constructor to MobileMapPackage takes either the path to a file with .mmpk extension or to the directory of an unpacked mobile map package. https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-mobilemappackage.html#MobileMa...
RitvikRanadive
ah i see! thanks a lot for all your help! we can close this one now...
