QObject::connect: No such signal
3734
03-09-2017 05:51 AM
NorbertThoden
I got following qt message. Obviously it´s caused by Esri:
QObject::connect: No such signal QRTImpl::TaskHelper::taskCompleted(QUuid, std::shared_ptr<ESRI::RuntimeCore::QRTTask>)
Is it worth to log a bug for this?
Or did you already switch from the old signal-slot-mechanism to the new one which is checked be the compiler?
Thx
LukeSmallwood
Thanks for reporting that Norbert, we will take a look at that error to try and see what the problem is. Do you have any steps to reproduce?
NorbertThoden
Unfortunately not yet.
It arises during a 3 day lasting debug session 😞
I will try to reproduce among the other esri-bugs i recognized ...
BTW:
We did you close the earlyAdapterForum also for the registered participant?
I think i have found a bug similar to them and now i can´t have a look...
Sometimes Esri drives me crazy....
Except Luke and Luke... 🙂
Thx
NorbertThoden
Hi Luke!
I have had a look to the logfile of our application, started/cleared yesterday morning.
The mentioned message was logged only one time..
And there was no context recognizable ... 😞
if i get this message again, i will let you know...
Thx
