Problem Installing QT for ArcGIS
3327
08-20-2013 08:52 AM
FabianHeredia
Good Day
I have a machine with windows 7 64x and install 2.7 install qt creator qt sdk arcgis, configure and create a QT application arcgis purchase, but this generates three errors when run, in library #include <QApplication>; solve it and change it between versions
I run the application and I get the following error:
Starting C:\Users\prosis\Desktop\QT\build-Prueba2QTEsri-Desktop_Qt_5_1_0_MSVC2012_64bit-Debug\debug\arcgis_runtime_sdk_10_2_for_qt_application.exe...
The program has unexpectedly finished.
C:\Users\prosis\Desktop\QT\build-Prueba2QTEsri-Desktop_Qt_5_1_0_MSVC2012_64bit-Debug\debug\arcgis_runtime_sdk_10_2_for_qt_application.exe exited with code -1073741701
EricBader
Honored Contributor
Hi Fabian.
Can you share the code you are using?
Are you using Qt SDK 4.8.4?
