PictureMarkerSymbol problem
4038
12-01-2013 10:32 PM
LeAnh1
Hi all,
I have a Graphic layer with PictureMarkerSymbol icon. How to symbol auto-resize when zoom in/out Basemap?
JeanneTrieu
The symbol is scaled automatically by the layer when you zoom in and out. Is there an issue with the current size of the symbols when you zoom in and out?
Regards,
LeAnh1
I'm using PictureMarkerSymbol with an image, then creat Graphic object, and add to GraphicLayer. When I zoom in/out, image's scale doesn't change.
JeanneTrieu
We have tested the issue with the latest 10.2 ArcGIS Runtime SDK for Qt and we were not able to reproduce the issue.
Are you using the latest version?
Regards,
EricBader
Honored Contributor
There isn't an automatic way to change the size of the icon once the size is set, regardless of the scale of the map. We don't have symbol scaling built into the software. Is this what you were asking about?
