output operator of Esri::ArcGISRuntime::Point
1342
03-15-2017 05:54 AM
NorbertThoden
I create two point and put them to QDebug/qCritical.
But i get unexpected results:
const Viewpoint &vp = mapGeoView->currentViewpoint(ViewpointType::CenterAndScale);
const Point &mapCenter = static_cast<Point>(vp.targetGeometry());
Point myLocation = mapCenter;
Point skyLocation = Esri::ArcGISRuntime::Point(mapCenter.x(), mapCenter.y(), 99999, sr);
qCritical() << " myLocation =" << myLocation << " z=" << myLocation.z();
qCritical() << " skyLocation=" << skyLocation << " z=" << skyLocation.z();
Output:
myLocation= 8.89179 53.0743 5.64578e-316 3.95253e-322  z= 0
myLocation = 8.89179 53.0743 5.64578e-316 3.95253e-322  z= 0
skyLocation= 8.89179 53.0743 5.74185e-316 3.95253e-322  z= 99999
The 1st and 2nd are clear.
The 3rd should be the z-value, right? But why 5.64578e-31?
The 4th is most likely the m-value (3.95253e-322) right?
Thx
LucasDanzinger
Esri Frequent Contributor
Norbert, this looks like a bug. I think there is some implicit type conversion that is happening. The x and y are correct, and the others are not z or m - they are just wrong. Can you please log a bug through support so that this gets put into the support system? Thanks for reporting! In the meantime, maybe you can use toJson() instead for debugging geometries.
-Lucas
LucasDanzinger
-Lucas
NorbertThoden
Hi Luke,
thanks for your information and tip (toJson)
I logged a bug:
  • Esri Support Case Number 01903553.
  • BUG-000103765 : The z and m value of Esri::ArcGISRuntime::Point provides incorrect result.
thx
NorbertThoden
Qt 100.4.0:
Qt 100.4.0: Issues resolved
  • BUG-000103765 The << operator outputs incorrect value for Geometries
