memLeak at ArcGISTiledLayer and Basemap
2231
13
08-28-2019 12:53 AM
NorbertThoden
Hi!
Does ESRI know that there is a memory Leak using
ESRI::ArcGISTiledLayer, ESRI::Basemap (V100.5 and V100.6))
Creating and destroing a simple map WITHOUT terminating the application.
Valgrind (@V100.5)
class ESRI::ArcGISTiledLayer
==24614== 15,592 (1,744 direct, 13,848 indirect) bytes in 1 blocks are definitely lost in loss record 835 of 855
==24614== at 0x4C2E2AF: malloc (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
==24614== by 0x40F5E69: operator new(unsigned long) (in /usr/lib64/libc++.so.1.0)
==24614== by 0xA877D11: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xA1FF237: RT_ImageTiledLayer_create (in /usr/lib64/libruntimecore.so)
==24614== by 0x5206BE1: ESRI::RuntimeCore::QRTImageTiledLayer::QRTImageTiledLayer() (in /usr/lib64/libEsriCommonQt.so)
==24614== by 0x525969C: ESRI::RuntimeCore::QRTArcGISTiledLayer::QRTArcGISTiledLayer(ESRI::RuntimeCore::QRTTileCache*) (in /usr/lib64/libEsriCommonQt.so)
==24614== by 0x55BCC65: QRTImpl::ArcGISTiledLayerImpl::ArcGISTiledLayerImpl(std::shared_ptr<QRTImpl::TileCacheImpl> const&) (in /usr/lib64/libEsriCommonQt.so)
==24614== by 0x49A566: Esri::ArcGISRuntime::ArcGISTiledLayer::ArcGISTiledLayer(Esri::ArcGISRuntime::TileCache*, QObject*) (in /shd/CTC/TOOLS/LTS-Esri-SupportDir/LTS-Esri/Prepared/LayerMemoryLeak/LayerMemoryLeak)
==24614== by 0x498C34: MapWindow::MapWindow() (in /shd/CTC/TOOLS/LTS-Esri-SupportDir/LTS-Esri/Prepared/LayerMemoryLeak/LayerMemoryLeak)
==24614== by 0x4971CA: main (in /shd/CTC/TOOLS/LTS-Esri-SupportDir/LTS-Esri/Prepared/LayerMemoryLeak/LayerMemoryLeak)
class ESRI::Basemap
(just the main leaks of ESRI::Basemap)
==24614== 4,288 bytes in 8 blocks are still reachable in loss record 806 of 855
==24614== by 0xC43FB01: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xC43A737: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xC43A2A2: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xC44343C: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xC442110: ??? (in /usr/lib64/libruntimecore.so)
==24614== by 0xA07D9D4: RT_ArcGISRuntimeEnvironment_setInstallDirectory (in /usr/lib64/libruntimecore.so)
==24614== by 0x5255D74: ESRI::RuntimeCore::QRTArcGISRuntimeEnvironment::setInstallDirectory(QString const&, ESRI::RuntimeCore::QRTObject*) (in /usr/lib64/libEsriCommonQt.so)
==24614== by 0x56C1574: QRTImpl::ArcGISRuntimeEnvironmentImpl::initialize() (in /usr/lib64/libEsriCommonQt.so)
==24614== by 0x4A21CD: Esri::ArcGISRuntime::Basemap::Basemap(QObject*) (in /shd/CTC/TOOLS/LTS-Esri-SupportDir/LTS-Esri/Prepared/LayerMemoryLeak/LayerMemoryLeak)
==24614== by 0x4985B4: MapWindow::MapWindow() (in /shd/CTC/TOOLS/LTS-Esri-SupportDir/LTS-Esri/Prepared/LayerMemoryLeak/LayerMemoryLeak)
==24614==
==24614== 4,288 bytes in 8 blocks are still reachable in loss record 807 of 855
==24614== by 0xC43A2DF: ??? (in /usr/lib64/libruntimecore.so)
and some more
I am already in contact with the support team, but no real progress ...
LucasDanzinger
Esri Frequent Contributor
Hi Norbert-
Luke was able to reproduce the issue you are seeing. We are still investigating the cause and will need to do an analysis on the affected versions. We've logged a work item internally to do this work, but please continue to work with support to get a bug logged through that system, so that we can properly link up the work items to your account. Updates to the status of the bug will then be made through the bug attached to your account.
Lucas
NorbertThoden
So, the ESRI Inc Support was finally able to create log a bug:
[BUG-000125025 : Creating and destroying a map created with ESRI::ArcGISTIledLayer and ESRI::Basemap shows memory leak]
But i am wondering abot the Support:
  • sometimes the operating system is not available and causes a delay of days/weeks,
    I assume that, they don´t tell, which OS they use...
  • the attached files do not reach the ESRI Inc engineer
  • the message does not reach the ESRI Inc engineer
  • The please me to sent a video to verify the intensity of an effects, but do not delievery a video what they see....
And this time they are not able to verify a memory leak due to missing skills
This forum is very often the last chance to get an issue solved!!
So, many thanks to Luke and Lucas to support me in getting a BUG-ID!!!
Greetings from Bremen
LucasDanzinger
Thanks for the feedback Norbert.
NorbertThoden
Hi!
Ich got the info that the bug should be fixed with V100.7 🙂
(Case 02386995)
Thx
