I am new to this SDK. I managed to run and compile a first app using ArcGIS Runtime SDK for Qt. however, I just get a black background without any map being displayed. Any help is welcomed. thanks.
Hi Mauricio, thanks for trying out the SDK.
Could you give me some more details on what you have so far?
Which Operating System (e.g. windows, mac, linux) and version of the API (e.g. C++ or QML only) are you using? Also are you using QML or widgets for your UI?
Luke
Many thanks Luke for your prompt reply.
I am running Windows 10, 64-bit, Qt 5.8 and the ArcGIS Runtime SDK for Qt, version 100.0.0. I created the project with the ArcGIS Runtime 100.0.0 Qt Widget app template.
Attached is a zip file with the project files.
Thanks, Mauricio
Dr. Mauricio Acuna
Senior Research Fellow
AFORA – University of the Sunshine Coast
Private bag 12, Hobart, TAS, 7001, Australia
Phone: +61 3-62375623, mobile: 0448372340
Email: [email protected]<mailto:[email protected]>
<https://www.linkedin.com/in/mauricio-acuna-71750329?trk=nav_responsive_tab_profile_pic>[ResearchGate]<https://www.researchgate.net/profile/Mauricio_Acuna>[Academia]<https://usc-au.academia.edu/MauricioAcuna>
Hi Mauricio,
I tested your code on my windows machine with Qt 5.6.2 and 5.8 and the map displayed in each case. Sometimes when the map is not displaying this indicates an issue with OpenSSL - see Install and set up on Windows—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
Do you have already have this set up?
Luke
Many thanks Luke:
I just installed OpenSSL and the problem was solved. Now the maps are displayed.
Kind regards, Mauricio
Dr. Mauricio Acuna
