Map is not displayed clearly
2317
6
07-14-2021 10:59 PM
KanjaSousuke
I use BasemapTopographic.
But, It's hard to get a clear view of the map.
Is this due to the performance of the PC, the network, or a problem with the code?
by Anonymous User
Not applicable
Hi @KanjaSousuke ,
do you have more information,
What product are you using and what are you seeing? Is there a chance that you can share an image?
If you think this relates to your PC, you can have a look at the requirements here: ArcGIS Pro 2.8 system requirements—ArcGIS Pro | Documentation
KanjaSousuke
Sorry for the late reply.
I use
OS: Windows10
Qt: 1.15.2
ArcGIS: 100.9
It seems that there is nothing wrong with my PC.
If I share an image, I'm only showing a map.
JaredCaccamo
Hello @KanjaSousuke ,
Is this in relation to ArcGIS Runtime SDK for Qt? If so which version are you using? Also could you possibly provide a screenshot of what you are seeing? Does an empty template with changing the Basemap to BasemapTopographic sufficiently reproduce what you are seeing? Also have you tried using Enums.BasemapStyleArcGISTopographic(BasemapStyle::ArcGISTopographic)?
Regards,
Jared
KanjaSousuke
I use
OS: Windows10
Qt: 1.15.2
ArcGIS: 100.9
I don't have initStyle because I have a different version of ArcGIS.
JaredCaccamo
@KanjaSousuke
Thank you for the additional information! I just want to double check that you intended to put Qt: 5.15.2 not Qt: 1.15.2. Also could you provide a screenshot of what you are experiencing?
"But, It's hard to get a clear view of the map." isn't quite descriptive enough without a visual representation as it could be a lot of different things.
- Jared
KanjaSousuke
Sorry.
After running it a few times, I could view it clearly...
Maybe it's a problem with the cache or something...
