Installation problems
3408
6
06-03-2013 05:48 AM
ZakariaNakrachi
Hello, I'm trying to install/configure the Qt Runtime. I have the visual studio 2012 express for desktop already installed along with the SP2. but when I try to launch the ArcGIS Qt Runtime, I get the error : that the install cannot be completed because it requires a supported version of VS2012 !
Any hint please ?
Also I would like to mention that the compiling of the Qt framework was painful because of some moc files included with the zip file. and also some makefiles make reference to some static links. so I needed to make some changes,
RichardWatson
I have not installed this but noticed that it seems to require Update 1:
http://developers.arcgis.com/en/qt/guide/how-to-build-on-windows.htm
Do you have update 1 installed?
ZakariaNakrachi
Thank you for you reply.
I have the VS studio express 2012. with SP2 installed. I cant get the SP1. and the link to the microsoft SP1 here http://developers.arcgis.com/en/qt/guide/how-to-build-on-windows.htm
is broken.
Please help/
ZakariaNakrachi
Does it support update 2 ?
JeanneTrieu
Thanks for your feedbacks. ArcGISRuntime SDK for Qt does support sp2 however the current version is looking for sp1. We will be removing this check for 10.2 final however the current beta version will have this limitation.
Regards,
ZakariaNakrachi
Thank you Jean for your reply,
Do you have any Idea when the final release will be available ?  or any workaround to make it skip the version check ?
JeanneTrieu
The final release date for ArcGIS Runtime SDK for Qt will be announce during the UC.  There is currently no workaround for this issue in the beta version.  It was indeed an oversight on our part. This will be corrected in the final version.
