In this example the load Status will not working in QML using ArcGIS
2646
6
09-29-2023 01:55 AM
Labels (3)
AyushiKamboj
 // connect to loadStatusChanged for each layer
                        encLayer.loadStatusChanged.connect(()=> {
                            if (encLayer.loadStatus === Enums.LoadStatusLoaded) {
                                loadedEncLayerCount++;
                            // loop through the layers and zoom to the combined full extent
                            if (loadedEncLayerCount === datasets.length) {
                                const fullExtents = [];
                                map.operationalLayers.forEach(layer => fullExtents.push(layer.fullExtent));
                                const fullExtentOfLayers = GeometryEngine.combineExtentsOfGeometries(fullExtents);
                                mapView.setViewpointGeometry(fullExtentOfLayers)
GKmieliauskas
Where is enLayer.load()?
AyushiKamboj
 layers.push(encLayer);
GKmieliauskas
Pushing to layers list is not layer loading. Look at the MapViewer template. Loading layer sequence must be like this:
                function loadVectorTileLayer()
                    mapLayers.push(layerUrl)
                    const tiledcustomLayer = ArcGISRuntimeEnvironment.createObject("ArcGISVectorTiledLayer", {url: layerUrl});
                    operationalLayers.append(tiledcustomLayer)
                    addLayerToContent(tiledcustomLayer)
                function addLayerToContent(layer)
                    if (layer.loadStatus !== Enums.LoadStatusLoaded)
                        layer.loadStatusChanged.connect(function(){
                            if (layer.loadStatus === Enums.LoadStatusLoaded){
                                // your code here
                        layer.load()
                    else
                        mapView.processLoadStatusChange()
                        mapView.setViewpointGeometry(layer.fullExtent)
AyushiKamboj
import QtQuick 2.12
import QtQuick.Controls 2.12
import Esri.ArcGISRuntime 100.15
import Esri.ArcGISExtras 1.1
import Qt.labs.platform 1.1
import QtQml 2.15
ApplicationWindow {
width: 800
height: 600
title: "Enc"
// property url dataPath
readonly property url dataPath:
Qt.platform.os === "Windows" ?
System.writableLocationUrl(System.StandardPathsDocumentsLocation) + "ArcGIS Runtime SDK Qt 100.15.2\ArcGISRuntimeSDKQt\SetupFiles\Data1" :
System.writableLocationUrl(System.StandardPathsHomeLocation) + "C:\Users\ADMIN\Documents\ArcGIS Runtime SDK Qt 100.15.2\ArcGISRuntimeSDKQt\SetupFiles\Data1"
property int loadedEncLayerCount: 0
Component.onCompleted: {
// set resource path
EncEnvironmentSettings.resourcePath = dataPath + "C:/Users/ADMIN/Documents/enc/hydrography";
// EncEnvironmentSettings::setResourcePath(defaultDataPath() + "/ArcGIS/Runtime/Data/ENC/hydrography");
// load the EncExchangeSet
encExchangeSet.load();
console.log("hydrography");
Rectangle {
clip: true
width: 800
height: 600
MapView {
anchors.fill: parent
// Set the focus on MapView to initially enable keyboard navigation
forceActiveFocus();
console.log("component");
// function setupEncEnvironmentSettings() {
// EncEnvironmentSettings.displaySettings.marinerSettings.displayCategories.standardDisplay = true;
Map {
Basemap {
initStyle: Enums.BasemapStyleArcGISOceans
EncExchangeSet {
paths: [dataPath + "C:/Users/ADMIN/Documents/enc/ExchangeSetwithoutUpdates/ENC_ROOT/CATALOG.031"]
property var layers: []
// connect to the load status changed signal
onLoadStatusChanged: {
if (loadStatus === Enums.LoadStatusFailedToLoad) {
console.log("fail to load", error.message, error.additionalMessage);
return;
if (loadStatus !== Enums.LoadStatusLoaded) {
console.log("here");
return;
// loop through the datasets
for (let i = 0; i < datasets.length; i++) {
// create an EncCell from each dataset
console.log("inside for loop");
const encCell = ArcGISRuntimeEnvironment.createObject("EncCell", {
dataset: datasets[i]
}, map);
// create an EncLayer from each cell
const encLayer = ArcGISRuntimeEnvironment.createObject("EncLayer", {
cell: encCell
}, map);
console.log(encLayer);
console.log(loadStatus);
if(encLayer.loadStatus === Enums.LoadStatusLoaded)
console.log("2");
console.log("if2");
// add the layer to the map
map.operationalLayers.append(encLayer);
AyushiKamboj
where you define mapLayers and layer?
GKmieliauskas
I just copied you some functions from AppStudio MapView template to show you layer loading pattern.
1. Creating layer object
2. Connect to loadStatusChanged event listening
3. Load layer
Look at Maps SDK For Qt sample
