How to set SpatialReference in C++
2466
05-30-2021 11:46 PM
Kanzakiryu
Hello.
I'm trying to use ArcGIS with C++.
I don't know how to set  SpatialReference for maps in C++.
Is there any way to do this other than setting it up in the new Map()?
header:
#ifndef CPPMAPS_H
#define CPPMAPS_H
namespace Esri
namespace ArcGISRuntime
class Map;
class MapQuickView;
#include <QObject>
#include <QMouseEvent>
using namespace Esri::ArcGISRuntime;
class CppMaps : public QObject
    Q_OBJECT
    Q_PROPERTY(Esri::ArcGISRuntime::MapQuickView* mapView READ mapView WRITE setMapView NOTIFY mapViewChanged)
public:
    explicit CppMaps(QObject* parent = nullptr);
    ~CppMaps() override;
signals:
    void mapViewChanged();
public slots:
    void fnSlotTest(QMouseEvent &mouseEvent);
private:
    MapQuickView* mapView() const;
    void setMapView(MapQuickView* mapView);
    Map* m_map = nullptr;
    MapQuickView* m_mapView = nullptr;
    //SpatialReference sp(6668);  <-GetError
cpp:
#include "CppMaps.h"
#include "Basemap.h"
#include "Map.h"
#include "MapQuickView.h"
#include <QUrl>
CppMaps::CppMaps(QObject* parent /* = nullptr */):   QObject(parent)
        m_map = new Map(BasemapStyle::ArcGISTopographic, this);
CppMaps::~CppMaps()
MapQuickView* CppMaps::mapView() const
    qDebug() << "TEST";
    return m_mapView;
// Set the view (created in QML)
void CppMaps::setMapView(MapQuickView* mapView)
    if (!mapView || mapView == m_mapView)
        return;
    m_mapView = mapView;
    m_mapView->setMap(m_map);
    qDebug() << m_map->spatialReference().wkid();
    connect(m_mapView, &MapQuickView::mouseClicked, this, &CppMaps::fnSlotTest);
    emit mapViewChanged();
void CppMaps::fnSlotTest(QMouseEvent &mouseEvent)
    qDebug() << mouseEvent.x();
    qDebug() << mouseEvent.y();
    const Point cPoint = m_mapView->screenToLocation(mouseEvent.x(), mouseEvent.y());
    qDebug() << cPoint.x();
LucasDanzinger
Esri Frequent Contributor
The spatial reference can be set in one of two ways. The first, most common way, is to add a layer to your map. The first layer, typically the basemap, will dictate what the spatial reference of the map will be. In the case of the ArcGIS Basemaps, most are in Web Mercator, so a map created with these basemaps will be in web mercator. The second option is to explicitly instantiate a map with a SpatialReference object, and then add your layers to your map after. The caveat here is that some layers, such as tiled layer/vector tiled layer basemaps, do not support reprojecting on the fly, so you will need to use layers that can be projected on the fly or publish your own basemap data in the spatial reference you choose.
More info on spatial references can be found here - https://developers.arcgis.com/qt/spatial-and-data-analysis/spatial-references/
LucasDanzinger
Kanzakiryu
OK, It worked.
Thanks!!!
