How to paint over mapview using CPP?
952
02-08-2019 12:50 AM
Girishchandra_Yendargaye
Can we paint or draw something over mapview? How to Do it?
Tags (1)
LucasDanzinger
Esri Frequent Contributor
If you want to draw in "map coordinate" space, then I'd suggest using our Geometry classes to create a Point, Polyline, or Polygon, and then display it on the map with a Graphic. That is showcased in this sample - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/DisplayInformation/GOSymbols at master · Esr...
If you want to draw in screen coordinate space and it doesn't need to stay tied to a map location, you can use any of Qt's mechanisms to draw, like QPainter.
