How to load elevation data?
1450
07-22-2019 03:08 AM
PaulrajJ
Hello,
I need to load a elevation data(dt2) into my map. Currently i'm loading map using the following method
void LoadMap() {
      MapGraphicsView*  m_mapview = new MapGraphicsView(this);
      Raster* raster = new Raster("map.tif", this);
      RasterLayer* rasterLayer = new RasterLayer(raster, this);
      Basemap* basepmap = new Basemap(rasterLayer, this);
      Map* m_map = new Map(BasemapType::Imagery, lat_value, long_value, 18, this);
      m_map->setBasemap(basemap);
      m_mapView->setMap(m_map);
In the above code how to add the elevation source(*.dt2)?
Tags (4)
LucasDanzinger
Esri Frequent Contributor
The workflow for setting elevation source via a dt2 is highlighted in the sample here - https://github.com/Esri/arcgis-runtime-samples-qt/blob/master/ArcGISRuntimeSDKQt_CppSamples/Scenes/C...
