How to delete Graphics in QML
1762
05-09-2021 11:50 PM
KanjaSousuke
Hi.
I try to delete Graphics in QML.
My code is
onMouseClicked: {
    clickPointBuilder.points.addPoint(cPoint)
    wayPointMakeGraphic.geometry = clickPointBuilder.geometry
    clickPointLineBuilder.addPoint(cPoint)
    wayPointLineMakeGraphic.geometry = clickPointLineBuilder.geometry
Item{
    focus: true
    if(event.key === Qt.Key_C){
        console.log("OK CLEAR")
        clickPointBuilder.points.removeAll()
        clickPointLineBuilder.parts.removeAll()
But, This code have a flaw.
I want to delete it  when I press the C Key.
It will be deleted when I click the screen again after pressing the C key.
How to delete Graphics?
Nicholas-Furness
Simply updating the builder will not update the graphic's geometry. After you removeAll() on the builders, you need to set the geometry on wayPointMakeGraphic and wayPointLineMakeGraphic from the builders again, as you do in your onMouseClicked method. This should set the geometries on the graphics to valid, but empty geometries.
Nicholas-Furness
KanjaSousuke
Thanks.
I can do it.
