How to create and assign user defined spatial reference for layers in ArcGIS Runtime sdk for qt 10.2.6
3077
08-07-2015 04:22 AM
kishorekumar1
     How to create user defined GCS, and specifying particular projection to use  along with created GCS and then using this
Spatial Reference for layers in ArcGIS Runtime sdk for qt.
From
Kishore Kumar
LucasDanzinger
Esri Frequent Contributor
Hey Kishore,
Can you provide some more details about your overall workflow? We do have a spatial reference class that will allow you to create a spatial reference object, then request layers be returned in that spatial reference. In this case, the server does the reprojection work and sends you the reprojected data back. Do you just want user defined spatial reference, or do you need actual custom projections?
Luke
